Line Weight Troubles
    I am having difficulty with controlling my line weights in the elevation view. Lines that should be showing up as thin (line weight 1) are showing up as thick lines and printing as such. These include the outline of wall openings. Wall base (which was created using a sweep in the wall type). grab bar which are a family and toilet partitions which is an in model component. I give you examples to help illustrate that it does not seem to be a specific element type.
    I have checked object styles to ensure that the line types are set to 1 and I have also checked the overrides to make sure non of these items have any graphic overrides associated with them.
    Any thoughts?
    I have attached a screen shot illustrating my dilemma. This is an interior elevation of a childcare toilet area (thus the half height wall).
    Couple of ideas....check what your Interior Elevations View Template shows....and check what pen #1 shows for Line Weights at 1/4"=1'-0" under the Manage Tab....
      GO in the Graphics Display Options and make sure Silhouette Edges isnt on. It looks like its on, and thats why multiple edges are the same lineweights.
        FIY on the Silhouette Tool
        The Revit Jedi: Using the Silhouette tool
        chad
          Sillouette was set. Thanks eveyone!
