Does anyone have a workflow for using trusses with the beam system tool. I understand they are separate categories, and I have tried nesting a truss in a beam family template with no success. Just wondering if anyone has a workaround so that if something changes, like spacing or truss type the change is simple without requiring a lot of picks and clicks to do the change.
Beam system behavior using trusses?
I think you need to array the truss instead of placing multiple trusses and dimension them. If you use Array, they are grouped, so you can change all trusses in one click, and you can easily change the spacing by changing it once and it will update for all instances.Martijn de Riet
Agreed, I don't like the beam system for much other than flooring joists.
With trusses I usually group the lot and copy the group. The reason I do this is that I like to trim up and cope my trusses first so they look nice and neat. This usually involves unpinning elements in the truss, so if you don't group them, and array them instead you get this ugly problem with the analytical lines all pointing to the initial location. I don't use analytical model at all, so for me both methods work, but if you are using analysis software be careful when you copy or array trimmed up trusses, they do not behave nicely.
Also I find that if my roof extents change, or some element supporting load is moved causing a modification in the truss, I only need to modify once rather than re-do my array, or clean up every single truss.
Hi everybody,
I’m becoming desperate and need some help. I’m trying to model a long workshop which is formed by a succession of 2D...-
Channel: Structure - Family Creation
June 21, 2013, 11:55 AM -
I tried to make a truss with a warren configuration, it is made as a 'structural truss family'.
The diagonals are always spanning 3 meters, I made...-
September 14, 2018, 12:32 PM -
Hi Guys
I have made a truss family and it works well. Now I would like to know if it is possible to do the following.
The...-
October 28, 2011, 12:35 PM -
Hi
Im new to Revit Structure (former Tekla user) as I just switched jobs.
I tried to design a truss, with help from the...-
August 22, 2011, 07:14 AM -
Hi there!
Anyone? ..
I can't figure out what went wrong with the Truss Family I created. I have two questions..
May 15, 2014, 03:29 AM -
