I'm tring to put E.I.F.S. cornice around my building. It has a gable roof, with some 3" bump outs (for a column effect).
First problem, I can't get it to work with a wide profile. I think it's because of the bump outs. So, instead of the cornice covering the entire wall thickness, it has to fall short. This isn't a huge problem, but I'd like a fix if anyone has one.
Second problem is huge. Revit is rotating the gable ends inward for some reason. You can really notice it at the top of the cornice, It's almost at a 30* angle. It should be level.
Here's an attachment. It's hard to see what's going on. I can post more stuff if you need it.
Here's the kicker. It's for a meeting tomorrow morning. So............HELP! :hide:
