Soo.. as promised and sorry for the delay, been quite busy. Give it a whirl, kick its tires, let me know if it helps you at all.
http://blog.bimkicks.com/post/2011/0...h-Upgrade.aspx
This is a little app I had put together some years back, it was meant to be a front end for the "Content Batch Upgrade Utility Tool" that ships on the REVIT disc.
Since I delayed publishing longer than I should have Autodesk has also stepped up and published an upgrade utility now available from the labs(http://labs.autodesk.com/utilities/adn_plugins/).
I would like to highlight a few differences from my app that in my opinion make it stand out :
* Installation not required (runs from wherever you extract it)
* Upgrade several file formats (rvt, rfa, rte - the labs version does as well)
* Quickly select and remove Files and FOLDERs for conversion
* Ability to inject CUSTOM journal commands to customize actions per file
* Selection to delete REVIT generated "0001" files
* Look cool while you're using it .. ;-)
