Unfortunately when i export drawing to dwg, some hidden things are shown. For example i used few white lines . Does somebody know how to export without unwanted "lines"?
Exporting to dwg - hiding lines
White lines arent hidden, they are white. That means they will show up everywhere EXCEPT in an application with a white : They export to CAD, they PDF or plot if you set colors to plot to black lines, they show up if you invert , etc. The only way to have them not export is to have them not really there, and white doesnt count as not there.
overide them, then when export use the tool to create new layers for overides, then just isolate that layer and delete. Or instead of making white lines revit has invisible lines or ref. planes. Why are you making lines you don't want to see? sounds like you want to look at visibility settings or something.Scott D. Brown, AIA | Senior Project Manager | Beck Group
Hi all,
I have a question about Revit export to DWG...Why when you export Revit to DWG hidden and thin lines appear lighter color than other...-
Channel: MEP - General
November 25, 2015, 10:05 AM -
Hello,
I have a Task, that I've never had done before. Manage the lines for the Export. F.E. my grid just on compact lines, it doesn't...May 8, 2017, 02:20 PM -
hi i have question how i can explode walls into lines in revit i need this method to use trick of creating complex ornamental shape save me time of...August 27, 2011, 03:34 AM
I'm a new member of the forum. I use Revit for several years now, but I had to make a export setup list for the first time.
October 13, 2020, 06:37 AM -
Hi and thanks to everyone who's answered and helped me out so far.
So I have created a precast stadium riser family (see image) and I am...August 27, 2019, 05:56 PM
