45 deg bend and pipe alignement
    Hello , I created a new elbow fitting with all the instances , when I draw the pipe at 45 deg the pipe doesn't align perpendicularly with the face of the elbow eventhough the connector is set to change its inclination according to the angle, does anyone see the problem, please check the picture
    I would suggest the usual suspects.. "Defines Origin" ref planes need to cross exactly where the pipes would cross. Connector on the moving end should have the Angle parameter linked to the elbow angle.
    • flush instead of elbow or new elbow family
      Hello everyone,
      I have a case that I am curious to solve and I need your advice. It is about pipe fittings. It may sound amateur however I want...
      February 16, 2014, 06:06 AM
    • Pipe Fittings
      I am modelling some pipework on a project and the main corridor has a slight change in angle (approx 2°). This is causing a problem for my pipe run as...
      October 20, 2011, 09:59 AM
    • Pipe Fitting angle precision on the fly?
      I've been racking my brain for an hour and still can't get this one figured out. I've managed to narrow my issue down and now I'm stuck. The issue is...
      November 5, 2012, 05:11 PM
    • Pipe fitting issue
      Hi There,
      I created three different elbows of 30, 45 and 90 degrees and corresponding branches . My requirement is , pipe should be able...
      January 29, 2014, 05:24 AM
    • Adjusting fitting angle
      Does anyone know if there's a way to adjust fitting angles after you placed the fitting and connected the pipe/duct?
      As for now,...
      October 11, 2019, 07:06 AM
