How much of a challenge would it be to switch to mep revit from an a architectural and structural
transition from revit arch. & structure to revit mep
Originally posted by Darius View PostHow much of a challenge would it be to switch to mep revit from an a architectural and structuralI'm retired, if you don't like it, go around!
Pipe fittings are pipe fittings - what matters is their arrangement. However, duct is an animal that is not easily understood. The arrangement and order is of course critical, but understanding the nuances of good constructible duct systems is not easily learned. Knowing what fittings are generally produced, which ones are generally not produced (even though your software lets you draw it), and best practices in fitting design are all very important areas to consider when jumping into the sheet metal side of things.
Sadly no ones really understands duct unless you've fabricated and installed it yourself.
Originally posted by MPwuzhere View PostWell....I went from Structural....to Aeronautical...to Civil to Architectural...
Although I recently attempted to go an MEP firm...never got a phone call...maybe advanced knowledge of Revit wasn't enough....
I am new to Revit MEP. Can somebody help me on loading all the duct and pipe Fittings family in to a already finished REVIT Structure Model....-
Channel: MEP - General
May 30, 2014, 06:58 PM -
Hell all,
I am taking REVIT MEP Cert. Professional Exam on Friday.
I passed both the Revit Structure & Arch exams recently....October 10, 2016, 02:40 PM -
Good Morning,
I am very new to REVIT MEP and I have been handed over a mechanical drawing that was drawn in MEP 2013. But when I run a duct...-
February 22, 2016, 12:58 PM -
One frequently overlooked requirement when creating fitting families (specifically elbows) in Revit MEP is that the vectors from the connectors, if extended...
Channel: Blog Feeds
August 9, 2011, 08:40 AM -
Hello everyone,
I'm working on a HVAC coordination project and there are a few ongoing issues with my fittings which I can't seem to solve....-
February 28, 2018, 04:53 PM -
