I would really like this to work better in Revit. This is a very tedious process (but thanks nevertheless!). Could it be so difficult to be able to swap rows in the properties palette?
It is crazy that the Factory hasn't come up with a proper way to order family parameters. You would think that this would be a relatively easy to programming task. I agree with you that the current work around is a bit of a pain. When I initially discovered this work around I almost didn't post it because it gives the Factory an excuse not to fix this problem.
Scott Hopkins AIA LEED AP
Peikert Group Architects
Hmmmm - could you be a bit more cryptic? I am not a C+ programmer and I know very little about data bases, but I do know that if there is a solid work around then that work around could be written into a script, and that script could then become a Revit command. So yes it seems that it would be possible for the factory to come up with a solution. Am I missing something?
I am working on a hood family that includes options up the wazzoo. Current count is 265 parameters in the parent family, most of which are duplicated...
I've previously created a new titlesheet with some additional shared parameters, loaded the titlesheet into the project and then added these additional...
