Can't Make Footprint Roof
    I'm wagering that it's an problem in the project of some sort but - I keep running into issues trying to make a small roof. The roof I'm trying to make is square and hipped on all sides. I've made a million of them in the past but for some reason this particular roof hates my guts and refuses to work. I've tried picking walls as well as just drawing the shape and I keep getting an error. I can dimension the sketch lines and the dims show the correct numbers for all sides (set to 1/256" tolerance) and the corners are all 90.000 degrees.
    Anyone run into this or have any insights to what might be the issue?
    edit: It only fails if I try to hip all 4 sides. any combination of hips & gables, shed or flat works fine, it is just the 4-sided hip.
    chad
    Try a less steep slope?
    It might be that the "peak" ends up with overlapping areas.
    Dave Plumb
    BWBR Architects; St Paul, MN
      get rid of the "two-cut" options and see if that helps, set it to Plumb Cut. Some roofs don't like that parameter.
      Scott D Davis
      Sr. AEC Technical Specialist
      Autodesk, Inc.
      http://bit.ly/aboutsdd
        Also try aligning all the eaves. They may be at different heights.
        Dan
          A square hipped roof = pyramid If it was a weird shape I agree 100% with this.
          It is set to Plumb Cut and all the eaves are aligned. It errors out when I pick walls or lines. If I draw the shape and manually place it everything is ok. If I try to align with the walls it freaks and gives an error. The only thing I can think of is that one of the walls isn't quite 90" but is 90.00001 or something ridiculous like that. :crazy:
          Thanks :beer:
          chad
            Maybe your broke Revit... maybe Revit is trying to tell you to be more creative with your design... maybe Revit is telling you to go home its 4:57pm on a Friday. Take your pick.
            -Alex Cunningham
              must be nice to be an hourly waged employee :hide:
                If only I were...
                -Alex Cunningham
                  I have had a similar issue, the roof was a bit more complicated but same thing. It should work, but just won't. I never found the reason either. In our case, the building footprint changed, which eliminated the issue for us.
                  Andrew Harp
                  BIM Manager GHD
                    I just ran into the same problem. Square hip roof, created with rectangle tool: "can't make footprint roof". Did you resolve this, or draw in lines in all relevant views :hide: ?
                    UPDATE: My original criteria for sketching this existing conditions roof was drawing a rectangle with an offset from columns beyond the building corners. When this was rejected by Revit, I then tried creating the rectangle by selecting walls (with a different offset, to get the sketch lines in the same place as the original roof). This resolved the Revit error. I have no idea why the other completely valid sketch creation method did not work, but this did. Whatever.
                    Last edited by lost again again; November 20, 2014, 04:40 PM. Reason: more information, including a resolution in my circumstance.
