I have a project directory legend that contains only text that I was hoping to transfer to a second project. However, when I used the "Insert from File" command and then chose to "Insert Views from File" the only legend that shows is a Keynote legend which I do not need. None of the other legend views are available to be transferred. Is there a better way to transfer a project directory between two projects instead of trying to transfer the legend view.
Thanks in advance for any help.
