i have a tiled surface pattern painted on to a floor with multiple slopes. all of a sudden i can't align the hatch patterns to each other in plan view. This was working perfectly until this morning...is there some sneaky setting i've accidently changed?
rotate painted pattern
have you perhaps aligned it (by accident)? Try changing the painted material and then change it back...Martijn de Riet
Is there a way to get my plywood hatch to rotate with my element? When placing a DC Plywood-Section, the hatch only runs horizontal. I need to draw...June 1, 2011, 04:39 PM
When materials with surface patterns are used, there is a good chance that you need to tweak its position, and perhaps even rotate it to some degree....
Channel: Blog Feeds
April 20, 2012, 05:45 AM -
i am new to revit and i am furniture designer i am facing really big issue with grains rotation of any wooden material
as you can see in this image...-
January 13, 2018, 06:26 PM -
I responded to a thread at Linked In this morning, something I almost never do. I find LI too frustrating to spend much time there. Regardless, the sought...
Channel: Blog Feeds
September 13, 2016, 05:15 PM -
Soooo i have no clue what i did with mine, i know i had a really good looking model and drafting pattern, for marble/granite. It had the veins,a bit...September 6, 2017, 10:12 PM
