Warning when opening file (keynote related?)
    When I open my building file, I get the warning: Duplicate key value '', text: ''
    I'm assuming that this is keynote related, but when I review the txt file, it looks like everything should be in order. What am I missing?
    We have had this problem on files with User Keynotes. Then the Keynote file changes and some old keynotes are in a view somewhere as a question mark instead of reporting a keynote value.
    Only thing to do is to hunt through your views and look for the keynotes not associated correctly.
    Darryl Store - Associate (BIM)
    [email protected]
    Twitter: @darrylstore
      you will want to export the warnings then search for those lines in the text file ...you will find that there are either extra tabs or spaces instead of tabs ...that is what it is saying
      -J
      http://about.me/JayZallan
      Tweet, Link or Blog me up!!!
        Can you Expand the warning dialogue and see an Element ID? (don't work with keynotes, so I wouldn't know). If so, write it down, click OK and do a search by ID to see what's wrong.
          Same text message is in txt file. Open with notepad, ctrl+F then search for this text and there must be two of them, then delete of of them, CTRL+S, close and enjoy
