Hey, i was working on walls etc and as always something messed up, in plan view appeared peace of the roof. Tried to join, unjoin, detach etc . nothing happened.
Any ideas?
Seems like the roof is being cut by the cut plane of the floor plan. Try using a Plan Region at that area with a lower cut plane elevation. Since this condition is repetitive in the design, once the plan region works well in one place, you can copy it to the other places where the same condition occurs.
I am working on an existing building where the ground is much higher on one side than the other. However there is a drainage area on the high side we...
This may be really simple but I cannot figure out why a Toposurface gets cut off at a certain height in a typical floor level plan View but you can see...
