Applies to: - Revit Structure
New Feature / Problem:
Area Reinforcement and path reinforcement do not appear in rebar schedules. This would be great if they appear in rebar schedules as well.
Area reinforcement is a command used a lot in reinforcement works of building projects. However, the problem is that this reinforcement does not appear in rebar schedules and rebar estimations. This is the problem.
Workflow:
Benefits:
Attachment comments:
Workflow:
Benefits:
