I hear talk of working views and printing views and it's pretty obvious that some people create a printing view from a working view. My question is: why do this? I create a floor plan, work on it, add to it, revise it, then flip it on a sheet and print it. What advantage is there to having a duplicate view for printing only?
Working views vs Printing views?
The main issue to me is that I can jack up a working view with hidden categories, goofy colors, whatever, and I don't break the printed set. In a single user environment this is less of an issue (no one is going to print not realizing the set isn't ready), but even then remembering what I changed (maybe weeks ago) in a view and making sure to change it back is a pain. "Sheeted view is sacred" is a pattern I follow no matter what.
I also believe in coordination views, export views and management views that don't change, so perhaps borderline excessive. But as long as they aren't open, a metric crap ton of usable views don't really weigh down a project, and offer a lot of convenient consistency.
Gordon
Hi Dave,
We use the working view more on files that have multiple users involved. It helps to erase the problem of people turning on / off items when they are working in the view and forgetting to put it back the way it was and in this process effecting the final plot.
If each user has a working view, they can have it display as they need when working without effecting the plot sheets.
This can be used for single users as well.Andrew Harp
BIM Manager GHD
Also important for projects with linked consultant models, once you setup how you want the consultant model to look for printing, you will often need to adjust the link display during co-ordination. With a separate set of working plans, you can make sure your print plans are not affected by temporary adjustments to the VG overrides for revit links, this becomes even more important when multiple users are involved
I have also heard them called modelling plans, it is just important for people to remember that they need to annotate in the print plans
Hi Dave,
I'm all by myself (when it comes to working that is), but I have always used working views for the following reasons:
-constraints. I can leave constrained dimensions sitting in view so I can always see where constraints are put. No need to worry on how it looks on sheet.
- categories on/off. I often deselect categories that need printing, simply because it's easier modelling. For instance furniture in a plan view. No need to check if everything is "on" when I print.
- Review items. I once posted a review family consisting of a simple block with shared text parameters in the Nurse Call Devise-Category. This is only on in my workviews, the category is off by default in all printing views (luckily I'm not in the healthcare-business!).
- I don't have those irritating tags/text/etc floating around my workview where I don't need/want to see them.
- I often use filters and colors to check the model if it complies to design criteria. For instance different kind of wall colors for different finish layers, etc. It's easier to check but I don't want them printed (unless off course when I need to consult the principal in which case I would create extra printviews)
Granted: a lot of this stuff only comes into play when you have to revise your work regularly. If your workflow really is Model-Annotate-Revise-Print-End of story, well then maybe you don't need this. But it's often Model-Add-Revise-Print-MORE REVISIONS-End of story. Work-/printviews are primarily useful in the second round of revisions (and all after that)Last edited by mdradvies; May 31, 2011, 05:53 AM.Martijn de Riet
thanks all for the great input! I use a lot of linked Architectural models and have run into having to turn stuff on and off as I work in the views then have to go to printing the views. It seems much better workflow to have separate printing views in this case.
Next question would be: how is this handled in Project Browser organization?I'm retired, if you don't like it, go around!
Originally posted by Bjorn_K View PostCreate a new Txt parameter (ie browser_org, folder etc.) in the Views Category, make a new Browser Organisation sorting on that Text parameter (and on Family&Type if that's what you prefer.)
Then whatever input you give in the Text parameter will create a new header in the PB.I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View PostI know how to set up custom Browser organization. My question probably should have been: what is your naming convention for working vs printing views and how do you sort them?-Alex Cunningham
Hello evrybody!
I want to print X-Rays views. The way that I apply is about printscreen and then I start modify. I hope somebody will tell me an...August 28, 2018, 08:29 AM -
Kinda what the title asks.
I was told by a few people that having more views existing in the project greatly bogs down the project. Not...December 27, 2012, 07:59 PM -
Hello All!
I would like to ask forum members about good practices on printing model documentation. I have adopted an AGILE methodology for...March 3, 2014, 04:06 PM -
When I get to work with people that have recently joined a firm that has been using Revit for quite some time the notion of working and sheet (or production)...
Channel: Blog Feeds
October 24, 2012, 01:15 PM -
Ladies & Gentlemen,
I have set up our project template to include view templates for modeling and for annotation where the modeling views...January 13, 2017, 09:33 PM
