help with massing plus curtain wall
    how do you apply a curtain system on a massing such that the grid/mullions follow the curve of a one 2d face.
    for example, one side/face of that massing is not a square (three sides are straight while one is curved), how do i apply the curtain system such that it wont look like a "square grid" superimposed in a non square face. i hope i'm clear. thanks
    #3
    sorry, i should have provided that, the first pic is what i'm getting, the second pic is what i want to achieve.
    btw, the design is from the book by eric wing that i'm using as a training book.
      I´m not a expert on Conceptual Massing (or on anything else for that matter). But here´s one way that should work:
      • Divide the opposite surfaces, and use the Surface Representation to turn on nodes
      • From an elevation view, create ref. planes between the nodes on each of the surfaces
      • Pick the main face, and apply a grid with "V Grid = 1"
      • With the main face/grid still selected, use the "Intersects" tool and pick the ref. planes you created.
      A picture speaks a thousand words as they say, so have a look at the attached screen dumps.
        thanks Munkholm. that's one possible way, however it seems to be tedious compared to the book, all he (the author) did is to apply the Curtain System to the massing and it seems to be automatic.
          Beats me then! But would be interested in knowing what the trick is... Anyone knows? Maybe someone have the book?
            Good day Barry
            I just ran a test and my curtain system does as per your manual.
            Quick Q are you using wall type curtain wall or are you using the curtain system?
            The wall type will keep Orthogonal axis.
            When you apply curtain sysytem the form drives the axis.
            If this does not help, please post a section of your project
            Cheers
            MW
              Hi Klaus
              Been a while
              How do I get an image up here?
              Just want to post a few snapsthat might help.
              Thank you.
              Cheers
              MW
                Reply > Go Advanced > Upload Attachment.
                Am waiting with anticipation to see the solution... can´t get it to work with either Curtain Systems or Curtain Walls
                  Ok I found it.
                  Have not uploaded since the change
                  Cheers
                  MW
