Some of us used to use planes of masses with a transparent glass material to add depth to elevations.
When I upgrade projects to 2012, these masses are no longer transparent.
Any idea why, or how to fix this?
The only fix I have so far is to set the Mass category to 'Ghost Surfaces' in the view, but I no longer have granular control over the amount of transparency.
You can play around with 3D views set as s, but that is annoying.
