Typically a structural grid will show "in front of" every object in a view, which is a good thing. So, if you had an object that had a solid black material on it, the structural grid, which is set to half-tone, will show up as a grey line over your solid black object. This goes for modeled objects as well as detail items.
While typically this behavior is exactly what you want, is there any way to turn this off? Is there a way to set the structural grid to show "behind" an object? We have several occasions where the structural grid lines up exactly with the edge of an object with the same line weight. The half-tone structural grid hides the object edge. And since grids show in front of detail items we can't even mask it in the view.
Suggestions? Work-arounds? Confirmation that I'm just SOL?
