Does anyone know why Revit doesn't support surface patterns for Topography?
Surface Pattern for Topography
I was going to say it was the compound curve problem, but I think the OGS fixed that. Unless I am mistaken you could not, once upon a time, get a Surface Pattern to map to a sphere, but in 2012 I just did it. Likely it is just a byproduct of the site being a bit of a kludge like stairs are, and when we get new site tools, perhaps we will get this improvement as well.
Gordon
I'm using 2011 so I guess thats it. Also, is there any way to remove a split line added to a floor without resetting its shape and loosing all other changes?
EDIT: NVM i found out that i just have to select the floor first and then click modify sub elements. Then I can proceed to delete split lines and points that I addedLast edited by JCM; May 27, 2011, 05:34 PM.
FWIW, the only part I could do in 2012 was map to a sphere, which in my case was an in-place wall made with a Revolve. Site still didn't work. But as I said, not surprised. Patterns still don't show up on stairs either. Because stairs remain a kludge in plan, and will until the whole underlying code base gets a revamp I suspect. Some things just can't be incrementally improved, they have to be redone from the ground up. Site, Stairs, Elevation Symbols. Little things.
Gordon
1. Release 2009 (in 2008), i believe.
2. I use slope defining lines if its a consistant and straight slope. if its non-uniform, or not straight, i use Shape Editing.
3. I make it one if its one rail in real life. If its broken in real life, i break it. (By the way, one rail is a misnomer, since Revits balusters are a boat full of fail. Every railing that i make in Revit is comprised of 3 "Revit" railings).
Aaron: OK, now what are the 3 railings? I guess its the guardrail part, separate handrail part and _____.
I asked about two railings instead of the one it should be because in my limited experience, I can't get a railing to be flat, then sloped. HELP is not helping...Last edited by lost again again; February 2, 2012, 10:53 PM. Reason: previously unintelligible. now semi-telligible.
Is it not possible to add surface patterns to site topography???May 19, 2015, 10:39 AM
If I have a regular rectangular surface pattern on a wharped floor, the pattern is wharped too. I can see what Revit is trying to do, but is there any...October 28, 2015, 03:43 AM
I have two adjacent rooms with the same floor surface pattern. I want to move one surface pattern Independent of the other one but revit always tries...March 5, 2014, 01:49 PM
Just stumbled on this one.
If you have say a timber deck and want to miter a corner there is all sorts of work arounds, Split Face alone never...-
Channel: Tutorials, Tips & Tricks
August 13, 2013, 11:14 PM -
I am trying to create a surface pattern for a divided surface (meant for use in a curtain wall). I can't even fine a file to copy/modify. These seem...July 17, 2015, 06:30 PM
