Error when trying to place a wall sweep
    I am using Revit Arch 2012 with vista. Everytime I place a wall sweep and try to close the dialog box, I get the following message "A serious error has occurred. The current operation has been canceled. It is strongly reccommended that you save your work in a new file before continuing. Would you like to save a recovery file?". Has anyone else experienced this problem? What was done to correct it?
    Thanks
    Max E Johnson
    Civil Engineer
    High Desert Homes
    Las Cruces, NM
    [email protected]
    Try and save the recovery file, and run an Audit on that file... Maybe that solves it?
    Havn't had the problem, or heard of others having problems with it BTW.
      Nope, never seen it. Does it do the same in a fresh project and new wall sweep profile family?
