Simple Test App Help 2014
    I'm struggling to get anything up and running on 2014 even using the Add-In Wizards for Revit 2014.
    I've stripped the code back to basics now just trying to get a simple message box to show something is preventing the app even getting to this point and it's doing my head in!!!
    Hoping someone here can spot it probably something so simple...
    App.cs
    Code:
    #region Namespaces
    using System;
    using System.Collections.Generic;
    using Autodesk.Revit.ApplicationServices;
    using Autodesk.Revit.Attributes;
    using Autodesk.Revit.DB;
    using Autodesk.Revit.UI;
    using System.Windows.Forms;
    #endregion
    namespace Test
        class App : IExternalApplication
            public Result OnStartup(UIControlledApplication a)
                MessageBox.Show("Test OnStartup");
                return Result.Succeeded;
            public Result OnShutdown(UIControlledApplication a)
                MessageBox.Show("Test OnShutdown");
    Test.addin
    Code:
     <?xml version="1.0" encoding="utf-8"?>
      <AddIn Type="Application">
        <Name>Test Application</Name>
        <Assembly>Test.dll"</Assembly>
        <FullClassName>Test.App</FullClassName>
        <ClientId>22e20807-aff6-4ed8-8503-a7f4f3b20ed6</ClientId>
        <VendorId>Test</VendorId>
        <VendorDescription>Test</VendorDescription>
      </AddIn>
    Both the dll & addin file are being copied to C:\ProgramData\Autodesk\Revit\Addins\2014 post build...
    There are no errors or warnings...
    Any ideas?
    Code is attached appreciate any help.
    Thanks,
    Nathan
    Try replacing MessageBox.Show() with DialogBox.Show(...).
    That way you will know if the problem is in the forms.
    Gonçalo Feio
      In Test.addin file:
      Maybe the extra quote in <Assembly>Test.dll"</Assembly>
      Or:
      Instead of:
      I would try:
      <Assembly>./Test.dll</Assembly>
      or
      <Assembly>C:\ProgramData\Autodesk\Revit\Addins\201 4\Test.dll</Assembly>
        Thanks tried these no luck not sure why. I tried using this wizard and it it amazing and works perfectly Revit Addin Wizards/Coders and Revit API Widgets - RevitNetAddinWizard & NavisworksNetAddinWizard
          Your ADDIN file needs to include <RevitAddIns>
          For example:
          <RevitAddIns>
          <Name>Boost Your BIM OmniFormat</Name>
          <Assembly>.\BoostYourBIM-OmniFormat\UniformatSearch.dll</Assembly>
          <AddInId>11a81a20-ed49-4341-aa1a-176782313b92</AddInId>
          <FullClassName>UniformatSearch.button</FullClassName>
          <VendorId>BYBM</VendorId>
          </AddIn>
          </RevitAddIns>
            Far out that would be it thankyou HarryMattison I will never get those hrs back but at least I now know not to delete those lines
            For example:
            <RevitAddIns>
            </AddIn>
            </RevitAddIns>
