I am having a problem where I have one room, a corridor, which passes through an existing wall in which I created an opening in and for some reason the room won't pass through the opening, forcing me to tag two rooms instead of one. This causes a problem on my finish schedule, where the room shows up twice. I have no room dividing lines in this location. Any suggestions?
Room is divided, any way to merge?
Originally posted by ekkonap View PostSplit existing wall
Have you tried that yet?Gonçalo Feio
How did you create the opening? Family or Wall Opening tool? (I'm assuming family since opening tool isn't phasable)
edit: Just confirmed this as working. Edit profile of the existing wall in the shape of the opening. Place another existing wall in the place of the opening and either edit the top constraint to match the opening height or attach top/bottom to the exist wall you edited profile of. Demolish wall.
This is similar to the split option but I think the edit profile is going to make it cleaner. Splitting always gives me the creeps, plus it would split all the way up so you'd be demolishing the entire height of the wall.Last edited by rkitect; May 26, 2011, 03:53 PM..Carl - Architect, BIM Manager, Father, Husband, Coach, Player, Disc Tosser, Driver... not necessarily in that order.
Originally posted by revittotd View PostSplitting always gives me the creeps, plus it would split all the way up so you'd be demolishing the entire height of the wall.There must be a better way...
Ekko Nap
Originally posted by ekkonap View PostWhat is the scariest thing you've ever done to a revit model? Trick or treat!!.Carl - Architect, BIM Manager, Father, Husband, Coach, Player, Disc Tosser, Driver... not necessarily in that order.
Originally posted by revittotd View PostRecreated 4 hours of lost work using a stitched Journal file. </iwin>
It occurs to me that I've sort of hijacked this thread. Stl, you good? Admins, any way to make a clean break? O, and maybe a way to post anonymously, otherwise I imagine the best stories will remain untold...There must be a better way...
Ekko Nap
Im trying to create a room in the red area (see attachment) called "Hal" but it sees the wall opening as the boundary so I cannot create ONE...March 22, 2013, 07:20 PM
Ok, i got a new question for u people
Im am working on a project with phases and want to add a wall opening in the new phase.
Tried with...December 17, 2012, 06:29 PM -
It's not as simple as it sounds. I'm trying to define an area within an open floor plan as a room, so I draw a room separation line, but when I do so,...November 22, 2012, 03:37 PM
Hello,
I need to get the list of openings and separators by room (like Room.Windows and Room.Doors)
Which nodes should I use?
Thank...-
Channel: Dynamo BIM
September 20, 2018, 11:18 AM -
Hello,
I have a problem which was already discussed in this forum but there was no answer.
I want to do an area...August 21, 2018, 07:53 AM
