Applies to: - All Verticals
New Feature / Problem:
Add the ability to control the default setting of Thin Lines at the launch of Revit.
Currently whenever you open Revit, Thin Lines is always set to it thick setting,(Where your lines represent the accurate line thickness) or "OFF"
It is bothersome to have to turn this setting ON every time you open Revit. It is something simple enough that it might even get done.
Workflow:
Currently:
Open Revit and turn Thin Lines on.
New Workflow:
Open Revit and have the settings to your liking.
Setting in the INI file or within the Revit Settings. Simple check box for ON or OFF.
Benefits:
Less frustration, little time saved. Seems like a no-brainer to me.
Attachment comments:
Workflow:
Currently:
New Workflow:
Benefits:
