Can a schedule capture information from 2 or more different types of area plans? Ie existing area plans and proposed area plans.
One Schedule Multiple Area plans
Not in 1 schedule since they are Phase aware.Martijn de Riet
We have an area plan of a multitenant building with the actual areas listed. In the area schedule, we have a column for Rentable Area. It there a way...May 1, 2019, 05:19 PM
I've created an area plan with several area types (BOMA). I can separate the types in the Area Schedule with a grand total. Is it possible to have each...January 25, 2017, 08:50 PM
When creating an Area Schedule I choose the Area Type eg. Area (Rentable).
Is there a way to change this Area Type later?
I had created...December 5, 2017, 11:55 PM -
When an area scheme is created, you have to choose an area scheme. Revit puts the Area Scheme name into the schedule title. If you subsequently make...June 3, 2015, 06:58 AM
Hello all,
I seem to be having a problem calculating the gross area of a small residential floor plan. The standard house plan has a First...February 25, 2016, 05:25 PM
