I'm having a very frustrating problem, and can't for the life of me figure out what happened. Hoping someone else has had, and solved, a similar issue.
A week ago, we had a Revit model with many happy room objects. At some point in time, all of the rooms became unable to find boundaries, and are now showing up as unenclosed room objects in the plan. I can't for the life of me figure out what happened! All of the walls are checked as "room bounding", the linked exterior shell model is checked as "room bounding", the room height offsets are all ok, etc. I tried cutting/pasting all of the rooms to the same place to see if they would magically fix themselves...that didn't work either.
I'm afraid it might be a problem with the file somehow. If I draw four room bounding walls off in space, on any level, and attempt to place a room object, that room object also can't find any boundaries! So it's not just a problem with the existing room objects.
Has anyone else had this problem, or any solutions I can try?
Thanks!
Thanks!
