When i edit stair Railing i got this massage (The Railing line must be a single connected Sketch. If you want separate pieces of Railing, create two or more separate Railing). if i make separate Railling its look bad......
I have an exterior deck with railing attached to the outside. I want to run a set of stairs along side and its railing, attached to the outside of the...
image shows problem I try to cope with. Railing starts from the top of first step what causes differences with height of railing. Each run is host to...
