I have electrical panels that are being fed from other panels. The demand factors are all set to power for panels. The loads show up fine in the top of the schedule but down where the load classifications and demand loads are it shows 0VA and 0% demand factor. (see attached) Panels are the only thing on the "Power" demand factor. What the heck am I missing???
Panel Schedules and Load Classifications
Same here
Originally posted by scooter67189 View PostI have electrical panels that are being fed from other panels. The demand factors are all set to power for panels. The loads show up fine in the top of the schedule but down where the load classifications and demand loads are it shows 0VA and 0% demand factor. (see attached) Panels are the only thing on the "Power" demand factor. What the heck am I missing???
I'm having exactly the same problem here, I'd like to use one of the parameters from the drop-down list (a demand factor) when editing the template and I just cannot make it work. The idea is to use the demand factor from the panels downstream to calculate the feeders. Once I apply the demand factors to the "clients" panels (the downstream panels), I have to re-apply some factors again to the "distributor" panel (the upstream one) to be able to determine the feeders. Any idea...?
How do you model Kingspan Metal Panels usually?
Looking for best practices, thanks!June 4, 2014, 09:50 PM -
Our Revit model is soon to be created in reality. The panels have arrived at the fabricator.
Click here to view the entire...-
Channel: Blog Feeds
November 23, 2011, 02:15 PM -
Hi all,
I have two separate electrical panels and i want to calculate the sum loads of the two. I'm refering to the Apparent Load of phase...-
Channel: MEP - General
February 18, 2016, 05:05 PM -
For electrical users, a somewhat common inquiry is how to document multi-section panels. Please watch the video below for a method that lets you utilize...
Channel: Blog Feeds
September 12, 2011, 01:20 PM -
Dear all,
How would you advice doing a corner part as shown in the picture? Is it supposed to be a new family panel, or one could adjust panelization...September 23, 2015, 12:49 PM
