Revit 2012 has better dual monitor capabilities. How does one activate this?
Dual monitor support
Control stuff has changed behind the scenes which MAY lead to better dual monitor control in Revit at some point in the future. In the meanwhile you can use the Autohotkey script I wrote a few years back and modify it to your needs.
It can be found at: http://revitforum.org/showthread.php...onitor-ControlIan Kidston
http://allextensions.com.au
Mmmm - I will check the zip file. In the meantime, I will PM the code to you.
Edit:
Just downloaded the zip file and it works perfectly for me.WinZip 15.5
Ian Kidston
Hi Dron,
Apologies for not getting back to your PM - tied up with some tribunal matters here.
The controls work fine for me.
For Plans, Elevations, Sections etc which will load onto the left hand screen, the shortcut keys are "crtl+shift+z" that is, hold down the control and shift keys then hit the letter z. Similarly, for 3d views, the shortcut keys are "Crtl+shift+s"
One small trick is that the view must not be in a Windows full screen view but rather in the restore down view (the toggle button in between the minimise and close buttons in the top right hand corner of the view). If it is set to full screen toggle it to restore down. The script is running a Windows command and it can't fight against another windows command which sets the view to be "full screen"
I had set the control keys up this was to ensure that they are nothing like any of the shortcut keys I use in Revit or elsewhere. I also use a Logitech G15 keyboard with programmable keys and have programmed three keys to run the command as a macro. Thus, for me to activate the command I simply push one key and off it goes.
It may well be that these shortcut keys don't suit you, in which case you can change them to whatever suits your needs.
As some people have reported problems with the zip file (although it works ok for me), below is the autohotkey code.
SetTitleMatchMode, 2
^F1:: ; F1 was used for demonstration purposes only. Choose a custom hotkey of your liking.
WinMove, Revit,,0,0, 3350, 1050
Return ; Stops the script from automatically executing further hotkey(s).
^+z::
ControlGet, ctrlH, HWND,, Elevation, Revit
WinMove, ahk_id %ctrlH%,, 0, 0 [,1370,950 ]
Send, zf
ControlGet, ctrlH, HWND,, Floor Plan, Revit
Send, zf
ControlGet, ctrlH, HWND,, Section, Revit
Send, zf
ControlGet, ctrlH, HWND,, Ceiling Plan, Revit
Send, zf
ControlGet, ctrlH, HWND,, Sheet, Revit
Send, zf
Return
^+s::
ControlGet, ctrlH, HWND,, 3D View, Revit
WinMove, ahk_id %ctrlH%,, 1370, 0 [,1665,950 ]
Send, zf
return
Further info:
Just noticed that you are running MEP. I had never previously tested it on MEP, but have just done so using MEP 2012, everything works as expected.Ian Kidston
Still trying to get this to work
Ian, Your help is greatly appreciated.
Sounds like there is a lot going on down under.
I have attached a screen shot of my Revit left monitor with the Winspy showing the details. Thought you might be able to tell if something looked out of place causing the script not to work. I am using Win7 x64 with Revit MEP 10, 11 and 12. This particular image is of Revit MEP 10.
I'll get a promotion if I can get this working.
thanks,
DronAttached Files
thanks,
Dron
Looking at the screen shot, it would seem to me that it may not be recognizing your version of Revit MEP and thus being unable to gain control.
The first thing I would try is to jump into windows explorer and find the exact name of the .exe file for Revit MEP. If for example it is Revit MEP 2010.exe, I would change the control line to read:
WinMove, Revit MEP 2010,,0,0, 3350, 1050
Once it has control, everything else follows from that.
Hope it works,Ian Kidston
I'm the IT person for a company and am trying to suggest the best monitor/resolution for our Revit user. I have read that a monitor...-
Channel: Hardware and Infrastructure
October 16, 2011, 12:28 AM -
Looking at upgrading to a 24" monitor and checking out my options. I'm using an 22" Acer LCD now and I've realized that the icons for detail...
April 11, 2013, 03:07 PM -
Wonder how this will work with Revit...
Maximum PC | AOC to Debut USB-powered 22-inch HD Monitor at CES
I think I found something...-
January 5, 2012, 06:58 PM -
Looking at a monitor for my sons gaming computer but am a little stumped with the different options!!??
The computer will also be used...-
January 14, 2019, 02:10 AM -
I've never put much thought into my monitors, I have a 15" laptop with a 22" monitor and initially thought I'd just get a second 22" monitor...December 16, 2020, 12:32 PM
