Hello again. Sorry for the sudden bombardment of questions, I really hope everyone doesn't mind. I will try to save the questions as much as possible but I'm a little stuck on this one. Here is a screenshot: http://dl.dropbox.com/u/4989089/05-20-11.png
(I have a big monitor so it's a big file)
This is an arch model from a tutorial dataset from an Aubin book my company purchased for me. Here's the scenario:
I'm trying to work a little bit like I do in AutoCAD MEP (split viewports, one side being a 3D orthographic view, the other side 2D plan view) so that I can see what's going on in both views. Is this not the proper technique? Thanks in advance.
*EDIT*
Also, how the crap do I get rid of the plumbing in all three levels when it's a Link? I can't select the groups and individually Hide them. Or can I adjust the view range on those Elements through a Level Parameter or something?
- Started with default Mechanical template
- Linked in Revit Arch model
- Copy/Monitor'ed the levels, created my floor views
- Created a 3D view via camera, cropped the view with a section box so the 3rd floor is visible
- started drawing in plan view, hopefully to see it in the 3D view, but nothing
*EDIT*
