Error Saviing editing mode Revit 2013
What were you doing when you got that message?
My guess is that you were editing a Sketch (Filled Region, Floor, Roof - anything that gets you into the "pink line" mode) and then you got a Save Reminder.
Or you might have been in Group Edit mode and tried to Save.
I't not a real big deal. That prompt just means that when you Saved your file, what it saved was before you got into that Edit Mode.
Your options are:- Live with it - in other words, you can accept the save as it is. By this time you've probably saved it again, anyway.
- Cancel the Save, finish your Edit and THEN save.
Dave Plumb
BWBR Architects; St Paul, MN
Most of us have all experienced the infamous condition where the "Finish Sketch" or "Finish Group" box disappears, leaving the user...March 2, 2012, 03:58 PM
When I enter the "edit group" mode there is no button to escape, I know there is usually a tick box but it has disappeared....-
Channel: MEP - General
October 13, 2016, 02:06 PM -
Hey fellas have a little issue that it seems, there is no answer to...the 'finish edit mode' tab goes missing. say i make a roof, on occasions it will...May 9, 2014, 04:44 PM
(a serious error has occured. it is strongly recommended that you use save as to save your work in a new file and continue in revit.) I have created a...February 15, 2018, 03:41 AM
I'm experiancing somewhat of a lockwdown.
Cant get out of a group editing mode, the finish button is gray, as well as the cancel.
...February 11, 2015, 06:01 AM
Monumetric Footer In-screen
