walls and curtain walls
    hello.. im stuck in my project right now. i created two arc walls shaped like a letter "S" and wanted to put curtain walls within them. the problem is when i drawing the profile of the curtain walls i notice that the endpoint in which the two of them meet has still a wall between them. how can i create a continous profile for my curtain walls? thanks
    Something like this? I drew my main walls, then drew the curtain walls to be embedded. While in sketch mode for the curtain wall, I used the Pick Line tool and selected the centerline of each wall.
    Dan
      that's the ugliest curtain wall that I've ever seen!
      signed,
      the curtain wall snob
        yes that one! does your method also apply with storefront? i noticed there's a tiny fraction of wall similar to a slice of pizza found between the point where the two mullions meet. i will try your method later on. thanks for the reply.
          signed,
          OOTB stuff dude. OOTB stuff. Modeled in about 20 seconds.
          I looked for the tiny fraction of wall (in my attachment it looks like there's one), but it's just where the 2 mullions of 2 separate curtain wall sketch lines are. I'm sure if I took the time I could get it to disappear...Or I could just send it to Dave to fix.
          Dan
            that would be great. also if there is a way wherein it can be just one continuous sketch and eliminate the two vertical mullions attached together.
            thanks!
