I am using the Revit/Google Earth plug-in to transfere a 3D model into Google Earth Pro. There are two problems I am having; 1) Only half of the model is being transferred; 2) I am not able to move the model around in GE (even when I change the "Properties>View>Latitude and Longitude" settings for the model).
I am modeling a 3D view in Revit 2012 and using the "Export Google Earth File(KML/KMZ)" command. I can't tell if the problem is in the generation of the KML/KMZ file or the import function in GE.The structure is very large and has many curved surfaces which could be part of the problem. Would appreciate any help.
