Question .. Have you snipped a portion from a JOURNAL File for scripting or reusing? For example, I have a journal file I run that can zoom-fit on all blocks, .. the line is simple:
If you use any .. could you share them with me, .. I am putting together a BATCH app that you can use to rerun journal commands on several files at once.
Jrn.Command "Menu" , "Redraw everything as large as fits into window , ID_ZOOM_FIT"
