some questions for you guys. did you ever tried exporting IFC from Revit?
If yes, did you ever experimented issues?
My point is that I've tried, using the specific template provided by the Factory (tested also before with the OOTB template); but with an average success; meaning classes in the IFC model are correct, but floors are not at the correct location, totally outside the building!!!
going further, I've imported the IFC created by RST, and the result in Revit is (see picture) that the floors are set at the project origin point.:crazy:
(rvt file is in the zip, can't upload rvt files, don't know why?).
For those who wonder what I'm doing with IFC, we have more and more needs to export datas from Revit to check models with others subcontractors, using Solibri MC.
thanks.
thanks.
