I'm a little confused.
I have a plan that is huge. It barely fits on a 30X42 sheet at 1/8 scale. So, I want to break it up on several sheets at 1/4" scale.
When I read the help on match lines, it says you first need to create dependent views. I guess I would have a dependent view for each part of the plan?
It also said that dependent view scales change as the parent scale changes. If this is true, how do I keep the overall plan at 1/8, and then the enlarged plans at 1/4?
