[Revit Architecture] - Railings - as a graphical construction
This topic is closed.
    Applies to: - Revit Architecture
    New Feature / Problem:
    Railings, balusters, posts and associated members should be constructed with graphic representations - lines, solids, sweeps, etc.
    We all know that Railings by data entry is hit & miss. For example: try to change the number of balusters per tread & hope for the best - and usually get a big serving of disappointment.
    Workflow:
    Create "Railing".
    Open dialog box, reference both Plan & Elevation.
    Sketch Run in Plan.
    Sketch (or insert Elements) in Elevation.
    Exit.
    Benefits:
    I'll be much happier.
    Attachment comments:
    Although I am not sure this would be the best way, I voted "Very Important" because I strongly believe that Railings must change.
    Revit Architecture - 3ds MAX Design - Octane Render - and many working hours...
