I'm trying to create a symbolic line in a Framing member that can be offset from the central reference by user input.
I have the offset side of things sorted, however, I'm having difficulty getting the symbolic line to cut back.
I haven't been able to find any solid documentation, however it appears that symbolic lines are automatically generated in framing members along the Centre (Front/Back) reference or possibly the reference that defines the origin in plan when the Symbolic representation is set to "From Project Settings"
It also appears that if I add any Symbolic lines "From Family" and not on the origin reference The Cut back isn't applied?
Am I correct in saying the above?
And that means that I need to create the cutbacks in the family?
Cheers
Cheers
