I am drawing an axonometric massing diagram to indicate zoning compliance, is it possible to lock a 3d view so I can't rotate yet still zoom and pan that is not a camera? Is there a way to do it with the view cube?
Locking an axo view
The wheel (shift + W) contains tools for zoom and pan, on any 3d view. You might be able to do it with the wheel of the mouse, too.
Also, in RAC2012, there is an option to lock the view. But just the methods described above should be enough.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
In a locked 3d view, in release 2012, yes, you can. You need to set work planes to change the orientation of the dimensions.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
I was wondering if it is possible to create a view out of a 3D view. I have for example this fascia 3D view on my screen, can I somehow create a view...April 19, 2016, 04:50 AM
Guys,
I'm not sure if I am missing something or if my expectations are too high, but I can't seem to edit (anything) in a 3D view. The...-
December 12, 2011, 02:39 AM -
I am trying to duplicate a 3D perspective view because I want to make a similar view with the same parameters in another area of the building. (I am trying...December 26, 2019, 09:40 PM
Hi. I have seen that this kind of view is possible in Revit but I cant seem to be able to achieve it.
Direct from above but in angled in...November 27, 2013, 09:18 PM -
hello, i was quite disappointed when i realised that an image can't be seen on a 3D view. example, in order to show where a (small) building will be created...February 1, 2021, 08:36 PM
