Small funniest Trick.
We can’t use Filled Region & Masking Region tools on sheets.
So that they appear to perform the following steps:
At now we have Filled Region on sheet !
This trick is funny because at first was idea, and then come up with how to apply this trick in practice.
For example we have several fasad's on different sheets, we want to make a sign with the symbols of finishes and placed on each sheet. Do some of the identical view are not comfortable, and this method is ideally suited. And groups keep link with each other.
- On sheet draw some detail lines and create a group with them.
- In a Drafting view draw the Filled Region and create other group with them.
- Place on sheet group with detail line, select it and replace it with a group with filled region.
