Hello guys, boys and gentleman. Today i am wondering and i would like to change visibility of filled regions compared zoomed in or zoomed out, in pictures u will see what i mean. Hardly visible is zoomed out. How to change it visible so it would be as surface patterns in or out zoomed? RAC2011
Filled region visibility
Also check the drafting pattern orientation. I've found that some of the orientation settings cause it to greyscale like this and others keep it bold. I can't remember which works best for which situations but I'd suggest playing around with that. (ie: Keep Readable, Orient to View, Orient to Object).Carl - Architect, BIM Manager, Father, Husband, Coach, Player, Disc Tosser, Driver... not necessarily in that order.
Originally posted by bangobeat View PostI wish, one part of slab edge joined floor, another "Can't cut joined element." so im using regions in section..
See the attached :beer:Attached FilesKlaus Munkholm
How can I control masking region visibility? I want to change line weight and color of mask region.
When I change visibility settings of Filled...August 27, 2014, 02:37 PM -
I have a detail component of a insulated CMU block. its pretty baisc. 3 filled regions and line work to go with it.
My problem is with...-
February 14, 2011, 07:05 PM -
Hi there!
Im quite new to revit. I am having a problem with the fill region tool. I am trying to apply a grid hatch to a bathroom to represent...May 16, 2013, 03:56 AM -
I'm working on some casework drawings where I need a filled region with a vertical hatch pattern. In a normal view my filled region shows up as a white...March 7, 2014, 07:22 PM
hello all,
i have come across a very strange filled region problem... i want to create a transparent gray filled region, and when i draw the...October 11, 2011, 02:45 PM
