Hepl!
    Hepl!
    I am working for 5 days on this project. Revit just suddenly clashed, and all my work has gone.
    Please help, what should I do? Is there temp files folder where revit stores backups, how to find locations of that file??????
    First of all, What are all those crazy lines?
    Second, usually there are files in the same folder as your Revit file with an extension .001, .002, .003 etc. These are back-up files check those to see if you can recover most of the work done.
    There are journal files from which you can rebuild the model but I can't remember where they are stored.
    Maybe one of the experts in here can point you in the right direction.
    HTH
    Juan Carlos Moreno
    Sisley Cosmetics
      Does someone know anything about that journal files?
      Revit 001 002 003 files are also crashed
        Did you import any item into your project that is not native to revit such as a DWG?
        If so, did you proceed to explode this DWG once in Revit?
        Juan Carlos Moreno
        Sisley Cosmetics
          Can you provide a link to dropbox for the file?
          Juan Carlos Moreno
          Sisley Cosmetics
            No, I didn't import anything!
            This is the link for the filr
            https://dl.dropboxusercontent.com/u/...61/kucica1.rvt
              I have good news and i have bad news, lol:
              Good news: The file doesnt look like that at all on my machine, it looks completely normal. No weird Lines anywhere. Is something else supposed to be showing up, or is this what it should look like?
              Bad News: If this is what the file is supposed to look like, i would start looking at a possible Hardware issue: Graphics Card that doesnt like Revit, or something similar...
              EDIT: Secondly, journal files can SOMETIMES be used to replicate work. Since im not sure you are actually missing any work, i cant say for certain. I HIGHLY doubt youll get it to build 5 days worth of anything. I consider it extremely lucky if i can get it to recreate work inside one session (a few hours), let alone a day. But it takes some work. The journals are stored in:
              C:\Users\YourUserNameHere\AppData\Local\Autodesk\R evit\Autodesk Revit 2014\Journals
                Same result here. Is hardware acceleration turned on?
                What graphics card & driver version do you have?
                chad
                  Just got a chance to open the file here and same as you guys.
                  Seems like a hardware issue.
                  Juan Carlos Moreno
                  Sisley Cosmetics
                    I restart my comp and after that everything was fine!
                    Thanks
