RSS Feed and Revit Communication Channel Compatibility
    Sadly, I must report that the RSS feed links for the Forums here on RFO are not compatible with the Communication Center RSS Feeds. Any thoughts on how to fix this? It's be nice to see new topics pop up.
    Seems like the Com Center is looking for a feed in XML format, but for some reason the external.php?type=xml is not working... Good thing is that this does work: http://revitforum.org/external.php?type=rss
    Note: external.php?type=rss2 wont work in Com Center either...
      Hnnn... that URL seemed to work, but I haven't been able to get Com Center to recognize the feeds from individual forums sections (as opposed to the entire message board). Any thoughts?
        You have to find a RSS reader that is compatable with RSS2 format. Most will only read XLS. Maybe Munk can supply a RSS feed that is in the XLS format for the forum. I am not sure how it works on the domain side.
        -Alex Cunningham
          Just suffix the above link with &forumids=X
          X being the Forum ID, e.g. http://revitforum.org/external.php?type=rss&forumids=2 for the "Revit Architecture and General Revit Questions"
            Alex, the forum feeds provides us with: js, rss, rss2 and xml formats to choose from, and the rss type worked fine in the Com Center... :beer:
            I believe that XLS is used for spreadsheets BTW
              On the main forum there is a small orange RSS button next to each sub forum. That button will send you to the RSS feed for this specific sub forum.
              -Alex Cunningham
                Bah!!! XML is what I ment.
                -Alex Cunningham
                  Correct, but it links to the RSS2 feeds, so you´ll need to strip the "2" if you want to use it in the Com Center.
                  :laugh:
