I'm having a problem to understand the mechanism of joining walls to floors
In the attached image you will see:
Detail 1: I was able join the wall to floor and extend the masonry core of the wall to the slab concrete and cleanup the finishes of both floor an wall, this was done when creating the floor and Revit told me that he will join automatically them
Detail 2: I used the Attache Top Bottom function to attache the wall to upper floor, but in detail 3;
Detail 3: I couldn't use attache top bottom to achieve the result in detail 2
Detail 4: Normally i have a problem with the first level floor and wall over it, they join only when I use the join tool, but I can't join wall to floor one by one in a big project,
So how can I solve these issues, easy approach to join all walls to floors?
thanks
Karim
thanks
Karim
