It's common to export Revit files to .dae format for rendering in Lumion, etc., but I got a whole bunch of textured buildings to use in InfraWorks that I'd like to get into Revit as a mass so I can use the mass floors tool and report rough square footages. I can export from Infraworks straight to .3ds, .fbx, or .imx but none of these import to Revit. I can export the .3ds file to .dwg, but I'd still have to recreate the geometry in Revit. Is there anyway to turn imported geometry into a native Revit mass? Also, would it be possible to preserve the photo textures from the Collada file so that I can eventually replace of of my .dae's in InfraWorks with .rvt's?
collada file to Revit mass?
I am able to open the .dae files in 3DS Max and export to various formats. I tried importing both .dwg and .sat into a mass family. Both give me the same warning when I load them into a project: "Mass contains only mesh geometry, which can't be used to compute Mass Floors, volume, or surface area." I want to import this geometry to calculate mass floors. Any other options?
I am familiar with 3dsmax and i prefer to realize my ideas through it. I had created a mass object in 3dsmax which is my conceptual mass object and exported...May 25, 2012, 09:58 PM
how can i bring a form from rhino or max into revit and make it behave like a form created as a conceptual mass in revit... i mean give walls and floors...July 29, 2013, 11:05 PM
I need a conceptual mass in a normal family.
I have imported inventor models before (export to dwg and import) and once imported you can explode...July 30, 2015, 01:18 PM -
Hi all,
could we Turn object into mass ??
In 3Ds max we can convert any object to editable mesh = mass ,and we can also attach to it any...-
February 10, 2014, 06:59 AM -
Hey guys
I got this dxf file with ''sail'' element in it and I can't figure out how to turn it into Mass... It's driving me crazy...
December 6, 2012, 10:00 PM
