Insert from File - Drafting Views
    Hello Everyone,
    I am having an issue on inserting from a file drafting views.When I get the dialog box that asks which view and only checking one and confirming only one checked they all come into the project. Is anyone else experiencing this or is it just another beautiful day at work with abnormalities? Thanks for your responses.
    try having all shown. then clicking uncheck all. after doing that you should be able to select just the one DV you want. Sometimes the select non dosnt uncheck views that are checked and not in the list.
    -Alex Cunningham
      Thanks for your help, I tried this but to no luck. Will keep trying.
        You can just mark the DV view want copied in the project browser hit CTRL+C, and go to the new project and hit CTRL+V - That should ensure that you only get that one DV to the new project... :beer:
