Mission impossible , wall
    Damnit spent like 2 hours trying to make something, i need to make wall as it shown on picture, but how can i make it? to the ramp i cant attach it, to the sloped floor above cant attach aswell . joins, or edit profile, or every second step writes Can't keep elements joined or Cannot extend layer(s) of the highlighted vertically compound wall. Please what would be your suggestion guys?
    Well, if all else fails you can always use the Edit Profile. Select the Wall in 3D or elevation view and click Edit Profile. Now you can sketch the profile as needed.
      Yeah as i expected Cannot extend layer(s) of the highlighted vertically compound wall. Very big surprise i failed
        Do you have any of the layers unlocked and offset?
          Could you post the project? Or a portion of it...
          Try Cutting to Clipboard and Paste Aligned to Same Place. This clears out any weird constraints you might have...
            Yeah i had unlocked layers, after locking it , i succeed! beauty! thanks Outstanding Revit Evangelist and Major Revit Evangelist. hehe
              I have a somewhat similar situation...What I'm facing is different in that the wall I'm trying to attach to the underside of a stair is also a wall that curves in plan.
              I was able to make a mass (with some difficulty) an place a wall on the face of the mass. However, the surface pattern in all messed up now.
              I need to do the same thing to the other side of the stairs and am hoping there is a better way to do this?
                Check out THIS thread. It may help ya.
                Dan
                  Yep, just posted to that thread too. Found it right after I posted here.
