Sloping pad issue - 2 pads intersecting each other
    I have put in a slopping pad on my site. When sketching the pad outlines I left "holes" in the pad for the lift overruns. I then modelled the pad for the lift overruns which are below the previous "main" pad. The problem I have is that the topo is not all cut - some of it is still "leaking" through.
    I thinkin gI have read somewhere that there is a problem with sloping pads when they intersect another pad. But what is the best work around - delete the point on the topo?
    Thanks,
    J
    EDIT
    I am using RST 2011
    Yep its a bug with pads, you just need to reset the height from offset level for the main pad. Since you are setting out by the slope arrow now, the height from offset level confuses the pad now
    See image below
    Revit BLOGGAGE
    http://www.revic.org.au
      Thanks mate,
      That was the probem - the slope arrows level was not set to the same Level as the pads.
      Cheers,
      J
