Roof Issues
    Roof Issues
    Hi everyone, I would firstly like to say that you have a great forum going on here so keep up the good work.
    I would also like to get your input on an issue that I have been having when creating a typical hip roof for a project that I'm working on. The roof that I'm designing consists of 450 eaves all around and has a 25 degree pitch. I keep getting error when ever I want to finish creating the sketch and I can only resolve this issue by making one of the edges of the roof a gable end.
    I have attached some screenshots to clarify the problem. As you can see form my sketch that this is just a typical footprint that you would normally sketch for a hip roof. I would strongly appreciate any ideas or input.
    Thanks
    1. Check all pitching lines are the same pitch.
    2. Check Align Eaves (all same height)
    3. make sure 450mm is consistant all the way around.
    Mark Balsom
      Hi and thanks for your reply,
      All lines have the same pitch and all eaves are aligned as well as being 450mm all the way around.
        Can you post the project, even if you copy paste just the roof into a blank project.
        Mark Balsom
