Im making a house that has the front walls higher than the sides. When i make the roof I can only set the constraint to one wall height only. So its either floating above some walls or going through some walls. How can I solve this probelm?
How do you create a roof for diffrent Wall heights
COuld you post a picture?Martijn de Riet
Originally posted by Scott D Davis View Postyou can also click on a sketch line of a roof, and change it's Plate Height parameter to make a section of a roof higher even when its created from the same sketch.
Also do you have any suggestions on cleaning up tile ridges? Mine are extruding through each other. Is there a way to connect them?
I uploaded pics of the house.
Off-topic- Would any one be willing to spend 30-60 minutes everyone once in awhile to screen share computers, so you could show me some tips and improvements for designing houses. I'm a senior in High school about to graduate and i really want to have a firm grasp of Revit before i attend college.Last edited by dlggnation; May 11, 2011, 05:27 AM.--
Originally posted by dlggnation View PostWhere can i find the Plate Height parameter? ...Attached FilesKlaus Munkholm
Could you post the file?Martijn de Riet
I have several roof skylights which are clad in standing seam on both the roof and the walls.
The roofs/angled walls were modeled as a...October 5, 2011, 08:39 PM -
Hi Everyone, long time viewer but first time poster here! I've found this forum so useful so thought I'd ask about this issue I've run into and can't...June 16, 2017, 11:24 AM
I had posted this earlier but I am still having problems.
I have a standing seam metal penthouse which is being built on top of an existing...November 15, 2011, 04:31 PM -
Historical - Double Pitched Cape Roof
I am trying to model a roof that has two pitches. The main part of the roof is a 9/12 pitch, that...September 6, 2013, 05:02 PM -
Okay,
So I got this split gable roof and want to create a roof in Revit.
Please suggest ways to generate it quickly, so...August 13, 2012, 01:43 AM
