Rebar in sections
    Rebar in sections
    I was tinkering around with the rebar placement and got it working (woo!) but the rebar shows up in all my sections, even when it should be covered by footings or other objects between the cut-plane and the rebar. Is this normal or do I have some setting screwed up?
    chad
    there is a different VG tool in the rebar properties box as well did you try that at all
    also when i worked at a sturcturual firm the way revit sturucture (2011) showed rebar, end bend, and tye conditions where just not good enough ( not enough variation). we drew it all with lines cause of the issues you are having as well.
      i did not know that VG tool was there :hide: It seems to do the trick, although it's a bit of a pain..
      chad
        i think that option is fairly new did not have that when i worked at the sturctural firm.
